(Disclaimer- This may be old news to some, but I've never heard it mentioned or tried. I'm pretty sure this will be a new discovery for most.)
Ok so I saw some recent discussion about the fan logic on Gen 4 cars and how you can't control the fans below 192* unless you use a custom OS. So I revisited my fan settings on my LSA Sky to see if I could tweak them a little better. I didn't like the idea of NO fans until 195.8* so I've been running my fans on low speed pretty much all the time. Kinda cr@ppy in the winter when I could drive back and forth from work and never really need them on.
So here's when the light went off over my head! A/C pressure! Refrigerant pressures run close to air temps, so I looked at the A/C pressure table in my E67 to see what pressures it had control over. The lowest cells are 600, 725, 850, 975, 1,000 and 1,225 kPa. Those convert to 87, 105, 141, 160 and 178 PSI. So I set up that table so the low speed fan would turn on at 141* and turn off at 105*. Drove it a few times and the logs confirm the low speed fan is turning on at ~136psi and off at ~103*! (A/C on or off, it doesn't matter. Obviously if the A/C compressor was on the pressures would be way higher but at that point you'd want the fan on anyway.)
So this is why I think this is cool... My cooling system is efficient enough that even on a very hot day, temps tend to stay below 195* which is the lowest temp that I would be able to control the fan. But what about when the coolant temp is ok (below ~190), but the under hood temps are really high? THAT'S when the A/C pressure is a useful input. It will show you what the temps under the hood and around the radiator/condensor are. (Log them and you'll be surprised at how accurate they are in giving you an idea of temps.) So now I can have my coolant fans stay OFF under most conditions when coolant AND underhood temps are low or ok. But not only will the fans come on at 195*, they will also come on if the A/C pressure gets up to 136psi, which is roughly 120* IAT temps. That's when you'd really want the fans to come on, especially when you have fans on a supercharger heat exchanger that are tied to coolant fan operation like I do.
Here's one of the scenarios I've already run into... 90* day, cruising down the freeway, coolant temp is nice and low and so is underhood temp. Come off the freeway and start doing some slower, curvy road driving. Coolant temp is still fine, but underhood temps are getting hotter. A/C pressure turns the fans on even though coolant temps are below 195*. Everything runs a little cooler with the fans running in that situation. Get back on the freeway and as the underhood temps/ A/C pressure goes back down, the coolant fan turns off. Fans aren't needed in that situation so there's really no need to be running them. PERFECT! Try it out guys and see if it works and helps in your particular situations. It's a "cool" alternative to not having ECT control of the fans below 195* without having to go to the custom OS. I'll take a couple screen shots of my fan settings so you guys can visually see what I did. Enjoy!
