Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: 2015 Z06 HPFP tuning.
    Anyone run flex fuel, overdrive crank, headers, and a CAI on a Z, and not run out of HPFP pressure? Lift pump is stable at 58psi or higher.
    Trying to see I'm looking at this the wrong way. I would think if I was getting everything from the HPFP, that I would get a drop from the lift pump.
    Am I just way off expecting that?
    Currently can't get pressure to stabilize. Drops to 8MPa before I lift around 4500rpm.
    Also, can anyone offer some insight into what the duration max value represents? Stock is 130.
    Thanks.
    Mar 2010
    Texas Hill Country
    3,299
    you can't run boost and E85 on the stock fuel system parts without lots of meth. BTDT....
    you need MPa to stay at 19+ or 25 or whatever you command in the tune.
    you need psi to stay at 70 at WOT
    look at your injector pulse width. if it is going over 5.5-6ms then your injectors are maxed out and draining your rails and working over your HPFP. I guarantee you your ipw is over 10ms and duty cycle is 35+
    you are out of injector and there are no bigger ones on the market....and now you know why everyone runs meth.....which also makes E85 pointless at this time for this application. However, depending on where your fuel system is exactly, maybe instead of E85, try E30 and see where it gets you.
    I've seen people go as high as E50, so I'm experimenting to see how high I can go with this combo. But I thought it was strange to have what looked initially to be ample feed and still a drop.
    Never logged lift pressure before I added the flex sensor. And it's been stable at 58, so I didn't believe it went to 70 at WOT.
    Time to blend in more regular gas.
    Tuning Addict
    Jan 2015
    6,819
    Higg's, will the cam lobe number upgrade support this? Only reason I ask is because with the cam I've had a z make 740 to the tire and was even better off to dial back the injection timing tables - Actually made it go richer instead of the usual "add to" method... I didn't log supply pressure, but high pressure maintained...
    Anyway I was just wondering if anyone had tried E-anything with the cam lobe upgrade?
    ~Greg Huggins~
    Mar 2010
    Texas Hill Country
    3,299
    from what i can tell, nothing will support boost and E85 and it's pointless to try until some much bigger injectors are available aftermarket....
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    This car was running full tank of E85, stock blower, auto made 720 wheel.... has 32% cam lobe...HP pump was still hanging in to 18 Mkpa. LP pump was at 48.....had no issues controlling fueling at .82-.83 lambda. We swapped out the stock blower for a 2300 and that's where it ended....went back to pump and meth.
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
    Tuning Addict
    Jan 2015
    6,819
    Howard, what did you finally wind up with on pump gas and the 2.3
    ~Greg Huggins~
    Jun 2006
    536
    They all seem to be around 765-775 RWHP and 775-785 RWFT.... this is pump/meth.
    Jun 2007
    Close to my Z06
    271
    Howard
    whats the benefit of going with the 2300, no cam, pullied vs the standard? pump gas
    Jun 2006
    536
    Quote Originally Posted by HNK View Post
    Howard
    Much to popular belief the factory blowers have more them proven there efficiency when used in there sweet spot. The 2300 use a bit more power to spin it so it needs to be used at 14-17 lbs to be worth it....then the overall mass of air that they move really should be pumped through an engine that has bigger camshaft and good exhaust..
    In all our testing on multiple cars the 2300 makes big low end and midrange torque and top end power is about 50-60 more then the stock blower....this is on average... as far as fuel that just depends on how hard you want to push it...
    Potential Tuner knjtuner's Avatar
    Aug 2022
    6
    This may have sealed it for me. I don't think E85 is the right thing for a Stock C7 Z06.
    Update: I just installed the DSX flex fuel kit. Now just waiting on my MPVi3.
    Aug 2009
    Calibrating
    3,374
    Quote Originally Posted by knjtuner View Post
    This may have sealed it for me. I don?t think E85 is the right thing for a Stock C7 Z06.
    Works perfect on a stock Z….
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2020
    Petersham, MA
    134
    Given the LT4 is octane limited on 93, even a blend of E85 is a massive improvement and a no brainer upgrade. Agree with Ben 100%.
    2017 Camaro SS, Whipple 3.0, Mast LT Black Label heads, 112mm TB, LPE BB HPFP & LT4+52% injectors, Fore Innovations triple pumps
    1059 WHP, 944 WTQ
    Oct 2019
    2
    Quote Originally Posted by Joshinator99 View Post
    Im running
    17 Z06
    stock boost
    only mods;
    AFE intake
    AFE cat delete
    DSX flex fuel
    E50
    Car is running 132.5 in 1/4 mile per draggy
    It ran 126 before the before mentioned mods.
    Fuel system is happy - pulsewidte is 5.4 I belive
    Commanding and obtaining .83
    2100 DA if anyone is interested
    Aug 2020
    Petersham, MA
    134
    Quote Originally Posted by donc7z06 View Post
    Im running
    17 Z06
    stock boost
    only mods;
    AFE intake
    AFE cat delete
    DSX flex fuel
    E50
    Seems perfectly reasonable. Keeping at E50 takes a lot of strain off the fuel system vs full E85, while reaping a good portion of the benefits.
    1059 WHP, 944 WTQ
    Aug 2022
    6
    Im running
    17 Z06
    stock boost
    only mods;
    AFE intake
    AFE cat delete
    DSX flex fuel
    E50
    I like your list of mods. Definitely in line with my thinking. No pulley, just basic mods for street use. I looked into downstream cat deletes xpiple but its apparently no legal and doesn't yield power. The catted down pipes do add power by still illegal.
    Aug 2009
    Calibrating
    3,374
    Removing cats has always added power… I’ve NEVER seen it not…
    14 Gen 5 Viper
    Aug 2020
    Petersham, MA
    134
    Quote Originally Posted by Ben Charles View Post
    …especially with a boosted engine.
    1059 WHP, 944 WTQ
    Dec 2019
    5
    If you think Lt4 stock is limited on 93, you should see it trying to operate under a normal pull on 91. Knock lights up like Xmas (In July, In April, in December - all the time).
    Even adding a few gallons of E will improve it remarkably. Let alone when the sensor input and tune is used.
    But maybe that's obvious.
    Aug 2020
    Petersham, MA
    134
    Quote Originally Posted by bc928 View Post
    It is for 99% of the people on this board but no harm in repeating it. It’s amazing how many Gen V owners still do not get this.
    1059 WHP, 944 WTQ
