My guess is the Baro pressure sensor settings need adjusted under engine diag-->airflow also under airflow-->general, make sure sensed MAP is enabled and set sensed MAP PR thresh which is .96 stock, down to .01 or so, this way the PCM actually looks at the MAP sensor.
From the dead AGIAN! having the same problem with a jeep. it doesnt even have a low/high error volt table for the map sensor to change. I fully don't expect a response, but just wanted to add that I'm having the same problem like everyone else and hope to figure it out soon.
You all are gonna love me.
Baro Volt Max set to 5.00V
Baro volt Min set to .50
make sure you go to air flow setting and Enable Sensed Map
Be sure to disable baro pressure fine tuning and learning.
also update the Linear and offset
Your welcome
