I just installed a Corsa on a 2013 Charger R/T and all is well as usual with a Corsa except when MDS is active at speeds 50 and under and then its according to the load. On flat road or low load its hums.
I see MOPAR has the minimum @9mph and Max @128.
There's also a separate set of parameters called ECO with the same settings. I thought they were one in the same? Somebody please explain.
Anyways I was thinking about setting the minimum to 50 and see how than goes.
