vss limit vs OP rpm and OP rpm min/max
does anyone know how these tables work?
output shaft (under fuel -> cutoff) - RPM limit vs OP rpm (under fuel -> cutoff)
speedo -> limit:
vss limit vs rpm
vss limit vs op rpm
output shaft rpm min and max
no one? lol
is there anywhere i can get this kind of info? guessing if its programmed someone must know its function, would support be able to help with that kind of thing?
i understand that i dont get many replies to the questions i ask as they're not common, but i emailed support and even they have no info other than what is listed in the software when you move your mouse over the table - which in this case is very little.
i'm not exactly sure what else i can do to obtain info like this?
