Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
Thread: Controller Unlocker: x36 Exceed Number of Attempts
  1. #41
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Quote Originally Posted by The Cleaner View Post
    Oh Hell, I didnt even look at the supported vehicle list to check that, I just assumed it would be supported.
    Any chance of HPT adding support for these f body pcm's??
    Unfortunately not, sorry.
  2. #42
    Dec 2020
    6
    What is the main difference between the 96-97 lt1 pcm and the 98-02 pcm of the f-body camaros that doesnt allow us to utilize HPT to tune the lt's? I had the same issue 5 years ago when i built my lt1 but i forgot what the issue was exactly. I had to pay for a mail order tune back then.
  3. #43
    HP Tuners Support
    (foff667)
    28,265
    Main difference is that it is a completely different ecm.
  4. #44
    ground pin
    i saw someone on you tube ground out a pin on the board but not sure what the ecm came from but does that work with the e38s too?
  5. #45
    Working on swapped vehicle.
    P01 from 99 Silverado.
    Read and wrote fine. Did Speed Density OS. Wrote entire fine. Trying to do adjustments.
    Getting x36 error.
    Tried to use GM SDS flash to stock - can't even start a write.
    Vehicle starts and runs. I can datalog and do RTT.
    Just can't write.
    P.S. I believe this happened to me long time ago before too. The SD was from a Camaro. Is F-Body OS corrupting truck PCM?
  6. #46
    FYI grounding pin on the motherboard revived both PCMs.
    https://www.customecm.com/gm-bricked-pcm-recovery
  7. #47
    Feb 2022
    5
    i want help please ...
    controller unlocker:x35invalid key ... how i can solution this problems ...?
  8. #48
    HP Tuners Support
    (foff667)
    28,265
    Quote Originally Posted by THINK View Post
    replace the ecm with one that hasn't been tunerlocked.
  9. #49
    Feb 2022
    5
    controller unlocker:x35invalid key ... how i can solution this problems ...?IMG_5479.jpgIMG_5479.jpg
    please i need help .. i cant open computer my car ...?
    Emil [email protected]
    thank you for all
  10. #50
    HP Tuners Support
    (foff667)
    28,265
    thank you for all
  11. #51
    May 2022
    1
    I have this same issue but I know its not locked because last tuner switched it from EFI live to HPT back in January and I flashed back to ECU live a few weeks ago now i can not read or write. i get the x36 message
  12. #52
    HP Tuners Support
    (foff667)
    28,265
    Quote Originally Posted by Gordo7722 View Post
    X36 means one of 2 things.
    A. ecm is tunerlocked
    B. nvram in the ecm is corrupt due to poor programming ie flashing a 2010 file into a 2008 ecm or vice versa
    Both require a new ecm that isn't corrupt/tunerlocked.
    Sorry to be the bearer of bad news.
