Video goes blank when I start to use the Trim Setting
I loaded a video into RaceRender, let it play to the point that I wanted to trim the start and as soon as I clicked on trim the video went black. I have restarted my PC, downloaded the latest RaceRender update to no avail. Any suggestions on what I am doing wrong. This is a picture showing what happens after I click on trim. The Start and End Screens are blank and if I try to set the start and end the main screen turns blank as well.
Bill
Most likely, it has something to do with the video format being used. The usual catch-all solution is to re-encode the video into another format (a .MP4 file with the MPEG-4 or H.264 codec should work well), or sometimes just using a different encoder can help.
If it was an AVI file, sometimes weird things happen with the Microsoft VFW system after you try to seek beyond a certain point in the file (usually 1GB or 2GB), which the Trim tool could cause to happen (if the file is that large). Basically, AVI was designed 20+ years ago and didn't support such large file sizes or many modern codecs, so the industry started using unofficial modifications and extensions, which are inherently problematic. A possible workaround is to install QuickTime 7 Player for Windows, and then use the 32-bit version of RaceRender, which can utilize the QT decoders.
