Results 1 to 13 of 13
Thread: Pilot Timing on Scanner
    I can't seem to get my Suite scanner to log Pilot timing. I found it in the parameters but i can't find in the channels where to select it. What am i missing? Thanks in advance.
    Tuner in Training Bdubbz's Avatar
    Mar 2016
    Utah
    29
    What year is yours? I don't think it works on the 03 early 04's. My 03 doesn't anyway.
    Tuner in Training Matt@HPTuners's Avatar
    Dec 2014
    39
    Have you reviewed this thread?
    http://www.hptuners.com/forum/showth...er-Information
    -Matt
    Mar 2016
    Utah
    29
    I have and I still don't have any pilot info coming through, I can only select it, just don't see any data.
    Apr 2014
    704
    Quote Originally Posted by Bdubbz View Post
    I experience the same thing with my truck. It used to work (from November to mid December), but quit working at some point after a HP Tuners software update.
    Just for clarification, what year truck are you working with?
    Mine is a 2005 Automatic, OS ID 25325353AI, CM848E ECM.
    Tuner Turbo_Mike's Avatar
    Feb 2016
    Putnam, CT
    130
    Mine also does not work. Maybe we need to re-patch? I always see pilot qty, so that lets me know when I break it or not, but I've never seen pilot timing or correction reason come up.
    2003 305/555 QCSB Cummins
    Piston/rod/sleeve/fire ring/dual CP3/300 overs
    Super Stick NV5600
    S366/S480
    Mar 2016
    Utah
    29
    I do see pilot qty but no timing or correction.
    2003 QC Long Flat Bed 6spd, Intake, Exh, Heavy Valve Springs, HE351VE Arduino
    Tuner in Training Derekb707's Avatar
    Feb 2016
    Eastern WA
    20
    Did this ever get resolved being able to log pilot inj timing on the 03-04 trucks? I am running the current 3.4.46 software, I load a channel list that has pilot inj timing included, but connecting to truck it disappears and does not log. Capture2.PNGCapture1.PNG
    2003 Cummins SRW LWB QC 4x4 NV5600 305/555
    Apr 2014
    704
    I don't think this is limited to 03-04 trucks, as I see the same thing happen on my 05. I can only suspect that HP Tuners engineering found that there was something off about what was being logged, and as such removed it from the supported PIDs until they can figure out how to make it work properly.
    Again, this is just my suspicion until HP Tuners finally tells us what happened to the PID (as it used to be supported).
    For all the people that can see PIDs.
    What ECM operating system do you have?
    Out of all the 2003-2005 trucks I have tuned can scan all the PIDs.
    Apr 2014
    704
    Quote Originally Posted by Moparmatty View Post
    25325353AI for me. 2005 auto truck.
    Feb 2016
    Eastern WA
    20
    Mine that doesn't log correctly is 05073548AK
    Feb 2016
    Eastern WA
    20
    Looks like the OS is not patched on my ECM file for extended data stream.
