im looking to gain some knowledge on putting a standalone 4l trans behind a SBC carb setup. i would like to tune the trans using HPT.
any input is appreciated.
Thanks,
Tyler
Thanks,
Tyler
I think it will be a bit difficult to make it all work with factory ecu without all the engine inputs for the transmission, to tune with HPT.
You best bet, might be getting a standalone controller. Like compushift, I know they make a good controller for the 4l60/4l80 transmissions.
Microsquirt controller with tps tach signal and output shaft signal. Or tci kit.
