'05 GTO M6
VCM Editor 2.24.1172
Able to flash PCM to 2 Bar OS and set the fans accordingly for a 160* tstat per http://www.hptuners.com/forum/showth...r-lack-thereof.
Started the car while data logging and ECT crept up past 200. Checked if the fans were running and they weren't. Re-seated relays, tried again and same.
Changed fans settings from 163* on up to 100%, let the car cool down, tried again and fans on full blast. Now I know that the fans physically work so it must be the tuning.
Changed fans settings back to original 160* tstat settings and fans not working. What am I missing?
BTW, after upgrading to the 2 Bar OS I replaced the MAP sensor with the appropriate item #12615136, test drove the car and all was well. Only change since then was changing the fan settings.
Suggestions?
VCMSuiteInfo 051416.txt
Fan Test 2.hpt
