Can I run HP tuners with engine only no trans?
Yes, you can.
Depending on what you are doing you can just delete all related transmission codes and operations just leaving it to control only the engine side. Some computer OS's allow for segment swaps to swap in a manual transmission file, then again it's just controlling the engine side only.
