Not sure if this can be done with software or if I need to use different o2 sensors. the problem is the o2's switch slow after moving them post turbo. the o2's are mounted at 6inches after the turbos. attached is a log of a 80mph cruise. the truck runs good but the afr swings from .92-1.02 trims look good but I keep getting slow switching o2 code after a week or so.I have tried to play with the P&I per thread( O2 Switch Points? No effect in Gen 4 E67 or E38?) with no avail. I could just disable the code but want to try to correct first. Any info would be help full.
5-17-17.hpl5-16-16o2.hpt
