Ladies and Gents,
I have a twin turbo Z06 with a fully built engine. I recently got the car all together and have been driving it a bit for the past month or two. Well, Sunday was the first time that I have run the car really hard as I was at a roll race. The car is still on very low boost but did make decent power. However, one problem:
On a few occasions, not all, I lost the throttle in 4th gear. As you will see from the scan, the throttle works fine in 2nd (launch gear) and 3rd gear, but in 4th, despite the accelerator position at WOT (85%), the throttle was only at 40%. It seems to be a computer/tune issue, not hardware issue since the commanded throttle is 38%. 4th gear WOT is from roughly the 39 second mark to roughly the 40.5 second mark. So far, it seems as though it has only happened in 4th gear but it may possibly have happened in other gears when I was not scanning.
Any help, thoughts, suggestions would be appreciated.
Josh
