so I have a 2005 C6 corvette that is procharged, heads and cam and long tubes and dual nozzle meth kit and LS3 intake. I started with a regular LS2 MAf and blew 1 apart on the dyno and was maxxing them out. so I swamped out to the LS3 MAF and did a ZL1 MAP sensor. I know its a 3 bar. so I was going to switch to SD tuning but had a few questions. On the 3.0 VCM editor under the OS it doesn't have 2 bar or 3 bar anymore? so is it already built in and you don't have to switch anymore? do I need to change any settings for the 3 bar map sensor?
next ? is I turned off the MAF, pulled off the pink wire off the MAF so it wasn't getting power anymore and when I went to start the tuning process I kept getting reduced engine power and couldn't go over 2k on rpms at idle or anything.
also on the SD tune do I go through and get the idle down like I normall would with the start up air flow and the everything and spark advance or do I go a different route. any help would be great I know there was a write up on the stickies but I didn't know if it was for 3.0 yet.
