Obd data registered in session?
Is the OBD DATA registered inside the track addict session or I need anyway to sinc it with racerender?
Any OBD data that you log with TrackAddict will be part of that session's data files, which also contain your GPS, accelerometer, and lap data. That will all be in sync together within the file, which would also be in sync with any video you have TrackAddict record using the phone's internal camera. If you use TrackAddict to trigger an external camera (ie GoPro), that should be approximately in sync as well, but will sometimes benefit from a little fine-tuning using RaceRender's Synchronization Tool.
