Hi guys
Having some issues trying to get the torque tables dialled in on a whole bunch of ROUSH supercharged mustangs we have been doing here lately.
I feel like I know what the problem is - please someone correct me if I'm wrong
With the FI stuff on the GT mustang, in the TM section, the torque, and torque inverse tables must be dialled in correctly to stop the car shutting throttle on you at different times and causing drivability issues.
I have logged INDICATED TQ and EXPECTED/ DESIRED TQ against each other, and whenever these two parameters seems to diff by more than 100nm or so, I can see the IPC WHEEL TQ ERROR pid increase dramatically, which perfectly coincides with the slight throttle closures we see when during on the road causing our issues.
What is the best method to get this table dialled in something blown or turbo for each of the different MP. I have the calculator to obviously created the inverse table for torque inverse.
Is it simply a matter of creating a graph / histogram with INDICATED TQ plotted against the torque table for each load point, and trying to populate this as well as possible? Given that we are supercharged, would you suggest rescaling the load axis (I have tried both ways so far)?
Any other tips or suggestions?
I have attached a copy of the current tune file so far - as well as a quick log from the street
THRILR_5.0_m6_eccroushblowerbase_warrantydetune_new_stockdd_stocktqinv_bestsofar.hptmustangipcwheeltorqueerror.hpl
