Page 13 of 13 FirstFirst ... 3910111213
Results 241 to 242 of 242
Thread: O2 sensor tuning with Headers
  1. #241
    Nov 2018
    27
    Make sure your wideband is right for one. O2 age will effect it too. Integrator needs to be increased to represent the further distance and then lower prop limit some.
    How much increase and decline per table? Would 10% on each table be good?
  2. #242
    Nov 2021
    25
    Hi, the wideband is OK, it works fine with other cars. I use the wideband stuck in the exhaust for speed density tuning.
    There's not any integrator table. I read on other threads that it is not available anymore on this ECM.
    What should I change to make it work properly?
    tune file attached.
    Update:
    I tried to lower down the Closed Loop Proportional Base vs. Airflow Mode and also increase Closed Loop Mode vs. Airflow. This did not change anything. I also tried the opposite way - Prop up, and close loop mode down. Also nothing has changed. Still reading lambda around 1.13-1.20
    any idea how to change the delay?
