Hi, the wideband is OK, it works fine with other cars. I use the wideband stuck in the exhaust for speed density tuning.
There's not any integrator table. I read on other threads that it is not available anymore on this ECM.
What should I change to make it work properly?
tune file attached.
Update:
I tried to lower down the Closed Loop Proportional Base vs. Airflow Mode and also increase Closed Loop Mode vs. Airflow. This did not change anything. I also tried the opposite way - Prop up, and close loop mode down. Also nothing has changed. Still reading lambda around 1.13-1.20
any idea how to change the delay?
