I'm working on a modified 2015 Manual Trans ZL1 with an odd issue.
When coasting to a stop the STFT suddenly shoots to +29% and makes the car run rich, causing the idle to surge.
Tried running in speed density only, maf only, and blended setup. Also tried with LTFT on and LTFT off, same issue every time.
Has anyone ran into this issue before? Is there a fix for it?
Attached is the log, tune and cfg.
Attachment 59665
Attachment 59666
Attachment 59667
