Results 1 to 14 of 14
Thread: setup for coyote single o2 sensor
    Jun 2014
    14
    Hello, I am working on a single turbo coyote with two o2 sensors in the downpipe next to each other. Turning number of o2's to 1 causes bank 2 to effectively quit firing. Can anyone shed some light on what other parameters need to be adjusted to make it work correctly? For that matter, is it really going to be necessary to turn one sensor off?
    Advanced Tuner AKDMB's Avatar
    Sep 2014
    NC
    344
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    ^ Follow the method I did in the thread AKDMB linked above. I had no issue running a single stock sensor with my setup after I did as Eric instructed in that thread.
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
    Jun 2014
    14
    That worked!
    What is inferred, but not spelled out in that thread, is that the o2 values must be all 0, not 1. 1 resulted in a no-start.
    Thanks!
    What year coyote you do this on. I Have a 2015 Mustang GT with a single o2 in downpipe and I turned sensors fitted to 1 and changed LTFT Bank vs CYL to all 0's and i'm missing nearly all the channel data when using the scanner.
    Aug 2008
    Kansas
    489
    Did you do everything listed in the thread on post #2? I was using a 2012 ECU in that thread, and had no issue doing it the way Eric outlined. It's a bit of a read, but I too had the scanner data disappear, until I did it exactly as he instructed, and then all the data came back, and it worked fine.
    '17 Whipple'd S550
    I have set the LTFT vs cylinder to all 0’s and I have set oxygen sensors fitted to 1. The only heater on is S1B1 everything else is 0 and the sensor bias is zeroed out for both banks and rear sensors are set to none. It runs on the one sensor but I can’t log anything I only see about 12 channels but maf period,Rpm,mapped points and VCT are all blank. Is there anything else I’m missing? I’m using Bank 1 sensor in downpipe
    Oct 2016
    Poland
    1,743
    I did that in a V6 twice - all good, no issues.
    figured it out I had to repoll the channels in VCM scanner to fix the issue
    Mar 2023
    28
    I know this is an old post, but would like to figure out how to change number of O2 fitted in the tune. Mine is grayed out and cant change it to 1, is there something I need to do to be able to change this on a 2013 Mustang .
    Aug 2008
    Kansas
    489
    Quote Originally Posted by Radialoutlaw View Post
    Have you taken the advanced parameter training to unlock the greyed out parameters yet?
    https://www.hptuners.com/emissions/
    '17 Whipple'd S550
    Mar 2023
    28
    yes i did and its still greyed out. resynced it, shut down and restarted.
    Aug 2023
    3
    Were you able to figure this out?
    Mar 2023
    28
    had to have someone send me a modified tune that i sent them from my car.
