Page 13 of 15 FirstFirst ... 39101112131415 LastLast
Results 241 to 260 of 289
Thread: Gen4 idle tuning guide
  1. #241
    When people here talk about Base Airflow, do they mean the Airflow Final Minimum table? Base Airflow sounds like starter values the PCM works with to determine desired idle airflow, while Airflow Final Minimum just sounds like minimum values. Unfortunately I can't find the former table anywhere. Increasing minimum idle airflow could of course have the desired effect, but wouldn't adjust for things like weather or the air conditioning compressor kicking on.
    Thanks. I've got a heads/cam LS7 with a NW 102 and the crankcase vented to a catch can. The TB scalar is set properly but it doesn't want to idle with much MAP (i.e. it just stalls). Presumably this is because of the lack of a PCV system, and me not knowing how to increase base airflow (yes the ECT scalar is set to 7,190).
  2. #242
    Dec 2011
    San Antonio, TX
    319
    Base running airflow, idle airflow, final minimum airflow, RAF, BRAF, etc that people refer to are all different names for each other. the table name has changes in different generations of controllers but same concept.
    Is there an open vacuum line to the engine now with the catch can install? I see this mistake made often.
    JTC Performance - Authorized HP Tuners Reseller
    Remote performance tuning
  3. #243
    Quote Originally Posted by charcoal03silvy View Post
    Thanks, that's very helpful. I wish the software described these tables better (or better yet published formulas); Final Airflow Minimum sounds like a floor, not the starting point, for desired airflow calculations.
    No there's no open vacuum lines anywhere. On LS7s, the intake manifold pulls air from the valley cover, which draws in air from the valve covers, which draw from the post-MAF intake. So I lost a source of intake air at idle.
    I increased the Final Airflow Minimum tables a lot and got the car to idle. It still stalls a lot due to the very light Tilton clutch/flywheel setup, but I think I've got a decent base to work from now. I'll go through the OP procedure now.
  4. #244
    I've gone through the OP procedure, and am not having any luck.
    Tune and logs are attached, but the pic summarizes what I'm seeing. Despite throttle position being fixed at 10.98% and timing at 22.00 degrees, it's very difficult to start it on a "stable" idle. Even then it oscillates from 950 to 1650 RPM over a period of about 2 seconds. Eventually it stalls. Decreasing Final Airflow Minimum, even by as little as 0.5 g/s, makes it stall much sooner. Increasing it makes it oscillate at a higher RPM. What I'm really having difficulty understanding is why the idle is sometimes more or less stable when throttle position and timing aren't changing.
    The car is an LS7 with Mast 305 heads, a Katech Torquer 110 cam, NW 102 TB, and Deatschwerks 65 lb injectors on E85. The tricky part is the Tilton carbon clutch, which is 17 lbs complete with flywheel. There's also no PCV system, which probably increases the necessary throttle angle.
    In this log I'm seeing significant negative fuel trims on bank 1, but that's not usually the case. The only other thing I can think to try is to lock it into open loop fueling, but I really doubt a few percent here or there will make much difference.
    Any suggestions? Thanks for any help.
  5. #245
    Jun 2014
    CT
    43
    Have you tried running MAF only to see if it still behaves that way? From the picture, the MAF looks relatively consistent through the surge/stall scenario while the VE is jig sawing. It may be worth a try with MAF only by setting dynamic air low: disable=100, re-enable=50. If it smooths out, it would suggest the VE tables need work.
    Just another thought, I've had idle issues with the LS7 card MAF on turbo setups that have lots of bends in the charge pipe. I've had great results installing air straighteners inside the charge tube just before the card maf to reduce the turbulence it sees and that has greatly helped tune out the idle surges. (your mileage with this technique may vary)
    11 Silveardo 2500HD Duramax
  6. #246
    Thanks, that might have helped a bit. I can get it idling at a lower RPM with MAF only, but it still eventually oscillates and stalls. Fuel trims are similar.
  7. #247
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    you are missing these. There a some that help with predictive and TB changes
    12940 - Requested Airflow Low Barometric
    12941 - Requested Airflow Medium Barometric
    12942 - Requested Airflow High Barometric
    Also [ECM] 2154 should be 6553 for your ECM and NW102. [ECM] 12087 is not right needs to trend not step. Your chances of getting idles with zero on adaptives are well zero. Your mods are too radical especially with no flywheel weight. My clutch assembly is 25 lbs and it is very difficult to get going without lurch and jerk in 1st and even some in 2nd.
    https://forum.hptuners.com/showthrea...l=1#post531912
    2012 ZL1 - Maggie Heartbeat, Port & Polish Heads, Custom Cam, Custom rotating assembly, steel sleeved LS9, No NOS and No water meth. 16psi
    810rwhp and 820rwtq 91 Octane 6400 rpm
    948rwhp and 951rwtq 105 Octane 6400 rpm
    999rwhp and 997rwtq on 60% Ethanol 6400 rpm
  8. #248
    Jun 2017
    6
    Quote Originally Posted by jsllc View Post
    I had to spend two hours reading through this whole thread and hours trying to tune my idle today to come to this conclusion. My setup is way to radical to turn all adaptives off and expect an idle. I've bit off a little more than I can chew. I have been researching for years, but just now getting my feet wet in tuning. I tried to add a bunch of extreme modifications and start from scratch due to a botched tune. I wanted to have an SD only tune. Easier said than done. After forcing closed loop in the scanner I noticed a lot of improvement. I think I'll concentrate on a MAF only tune and fix my VE table later. I did learn that I needed to modify my [ECM] 2154 and [ECM] 2174 to account for my 102mm tb, so that should help a little with tuning tomorrow. I also need to look into modifying my EIOT due to my cam I think.
    Oh, my car was idling between 1500-1700rpm and I couldn't figure it out. Adjusting "Airflow Final Minimum" and timing wouldn't bring my rpm down. It would make it harder to start or to keep running though.
    '09 G8 GT
    SBE, MAD ported LSA 2.38/10, 210lb inj, 102tb, 238/242 112, ls7 maf, SD 2-bar.
  9. #249
    Aug 2018
    292
    That doesn't necessarily seem like the best cam for an LSA blower based on the specs in your signature, but you should be able to get it to idle with the adaptives off. It sounds like you fixed your TB scalar, but I'd also go hit the basics again just to make sure you didn't miss anything: make sure your injector data is correct and get the air/fuel dialed in pretty closely at idle before you start fine-tuning it, etc.
    This idle tuning procedure is actually the last thing to do in my book. It will put the final polish on idle quality and get the airflow and spark corrections to stop fighting each other, but I wouldn't bother with it until the rest of the tune is good.
  10. #250
    Jul 2018
    Washington State
    17
    Hello All, there is so much good information in this thread! But being that Im so green at this, the more I read the more confused I get. I have been taken shots at trying to get my idle dialed in after upgrading my camshaft and lifters. It starts and idles on its own, but it has a shake or shutter when it sits at idle. I was wondering if anyone can take a look at my latest adjustments and see if you could tell me if for one, I am heading in the right direction, and if you have any suggestions how to get this shutter to smooth out?
    2015 Toyota Tundra Limited 4X4 5.7L
    K&N Cold Air Intake
    2006 Base LS2
    Pfadt 1 7/8" long tube headers w/ 3"collectors, Tick Performance 231/235/111, Comp Cams Ultra Gold 2122 1.82 ratio rocker arms,
    X-pipe, high flow cats, Z06 mufflers , Vararam power wedge, and BC coilovers,
  11. #251
    Dec 2019
    MS
    568
    Tagged for future reference.
    Tuned a 6.2 with a cam last night. Then found this just now. Wish I'd read this before starting.
  12. #252
    Jan 2020
    1
    Does this method work with a SD tune also
  13. #253
    Jan 2014
    Australia
    1,977
    Quote Originally Posted by Race gto View Post
    when maf is failed the effective area max fail comes into play so set it to like 200 but aside from that is all the same method
  14. #254
    Mar 2020
    8
    Awesome info in this thread!!
    I picked up a '13 CTSV that made its way from Denver to Houston and has the Lingenfelter 700+ package and the dealership couldn't find record of the actual cam spec's. It does have a noticeable lope. My MPVI2 arrived on Monday so I'm picking up where the other tuner left off.
    The idle is relatively stable but hunts a little after rev up or coming to a stop.This is my first attempt to retune it, as it's very rich and the fumes are not just from exhaust (longtubes with cats) but also there's noticeable stumbles on quick acceleration, and very lazy startup after warmup. I've followed the procedure Mike put together and I have the idle stable now, whereas it was dying and wouldn't idle without partial throttle, but I'm having a massive amount of frustration of getting it to stabilize the idle after reving up or coming to stop on coast down. Even when I pull in my garage, it will stall with partial throttle.
    Should I continue to work on the Airflow Minimum table or work on the Spark base table? Attached is idle and drive log, along with the current tune.
  15. #255
    13,557
    Fix the fueling before you worry too much about tons of idle changes. If the fueling is all wrong, so will your idle airflow adjustments.
    That tune needs some help for sure. Look at how stupid rich they setup power enrichment. It floods the engine with fuel and I have no doubt that is part of your bogging problem.
    14.68/1.500 = 9.78 AFR. This massive dump of fuel can cause some of your knock retard as well. No idea what the hell this previous tuner was thinking. For now just change the whole table to 1.300 (11.2 AFR), that is nice and safe while you fix other issues.
    Invest in a wideband 02 sensor, this is a must for tuning. You'll want to go over the MAF curve and VVE to get fueling squared away. Things tend to go smoother or fix underlying issues when it's not overly lean or rich.
  16. #256
    Mar 2020
    8
    Absolutely investing in a wideband. I just ordered, tonight in fact, the AEM x-series controller w/ gauge; will take full advantage of the Pro input. What is the path to the table you're referring to for making the change?
    I can only imagine the previous tuner, who is in Colorado was doing something for the change in DA up there, but I've also found that certain things were let the same as the stock tune when I compared them, such as final air, startup air and ETC area scalar.
    It does have ID 850's and a Nick Williams 102mm TB, but it seems they just made adjustments on the Injector Controls and Flex Fuel. It does have a AEM flex fuel sensor but I'm also going to replace that with the GM model since it will report PID to the instrument panel.
    Thank you for the input.
  17. #257
    13,557
    Engine > fuel > power enrichment and then EQ ratio. That is the commanded fueling value for power enrichment.
    Being Colorado doesn't really matter, the car has enough sensors for MAP/Baro, IAT, ECT etc etc to help figure out what to do. They don't make different calibrations for stock vehicles for the people that live in Arizona, the Canadian Yukon or pikes peak type of thing. I just don't think they understood what PE does and how to use it. Power enrichment EQ ratio is a set and forget table. You are making a request and the goal is to match that request by getting the data correct in the MAF/VVE. If you ask for 11.2 AFR but see 10.5 or 12.0, that just means there is large error between what is commanded and what is coming out the tail pipe. Adding or removing "fuel" from the airflow model is how things get fixed.
  18. #258
    Mar 2020
    8
    Totally understand what you're saying, appreciate the insight.
    I'm going to set the EQ to the value you recommended and see how it reacts.
  19. #259
    Dec 2016
    41
    I just installed a BTR centri cam in my ECS supercharged 08 vette. running open loop sd tune for years. I cant get it to idle under 1100 rpm even when commanding lower. I was tryng to start at 900 and work my way down. when I set the airflow lower, the throttle will start searching while timing remains constant. lowered timing down to 10 degrees and all that did was open the throttle a few degrees to compensate. I installed new plugs and checked all my vacuum lines. when it will idle at 1100, i sprayed carb cleaner all around intake and it didn't change anything.as I try to road test, it drives fine, but will die when making turns or stopped at stop light. my VE table is a mess since I haven't really been able to get out and drive, but at 1100 wideband is reading 1.1 to 1.15 lamda 45-50 kpa. keeps leading me to believe I have a vacuum leak, but I cant find one unless the bov is leaking.
    this idle tune made up for this thread is attached.idle.hpt any ideas would be greatly appreciated.
  20. #260
    Jan 2009
    Spokane, WA
    480
    Quote Originally Posted by russ472 View Post
    Lots going on. Try the stock tune.
