Page 8 of 15 FirstFirst ... 456789101112 ... LastLast
Results 141 to 160 of 289
Thread: Gen4 idle tuning guide
  1. #141
    Apr 2014
    18
    Okay please tell me what I am missing here. I don't have the tabs options in my HP Tuners that you guys are wanting me to adjust.
    And as far as the Idle tab I can go Idle->Airflow and that's it....There is no tab for Startup at all......
    Please tell me what I am missing.
  2. #142
    Jan 2014
    Australia
    1,982
    startup airflow is in the "idle" "airflow" tab under startup within the tab, make sure u have the view on advanced also so everything shows up
  3. #143
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by No fear View Post
    Make sure you're in advanced view first.
    edit, view, advanced
  4. #144
    Tuning Addict
    Jan 2015
    6,802
    Quote Originally Posted by Higgs Boson View Post
    I wouldn't say a lot more. Basically, you let the cam do it's thing regarding it's lope and then allow correction after that, which you know that already.
    Find the right Base Airflow for the cam at about 50 RPM higher than desired and let the Spark Adapt pull about 5 degrees out to hit desired RPM. Of course the numbers will vary depending on the combo.
    I'll post the latest tune I am doing this with next weekend if you remind me.
    BTW, with the Spark Adapt pulling out spark you are no longer technically at MBT I wouldn't think. Actually I don't think I have tuned an auto GenIV in a long time. You can set Base Airflow different in Park vs Drive/Gears so if I get an auto to mess with I will try it out.
    ~Greg Huggins~
  5. #145
    Mar 2010
    Texas Hill Country
    3,299
    Still not done. the builder had/has some ground issues to sort out. half the time the throttle won't open past 30%, fuel trims go to 0%, etc.
    It's 99% done, I just want to make a WOT MAF pull or two. Maybe this coming weekend.
  6. #146
    Been following this to tune the idle for my friends turbo 2008 gmc truck. Truck idles and is now drivable but only issue is it likes to stay 200 rpms higher than desired. I have tried lowering base air and changes a little. Tried adding timing but rpm goes higher as i do.
    We want is at 800 rpms so i went with 500 target rpm and it idles at 800 now. But i know thats not the right way, what can i try next?
  7. #147
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by Vasquezz1228 View Post
    Less air and/or less timing.
  8. #148
    Brought timing down to 0 and base airflow to around 3gs but still idles at 1000 rpms and goes down to desired and right back up. Seems like no matter what i do it idles at 1000 rpms with 6 degrees timing
  9. #149
    Aug 2014
    Central, LA
    737
    Stock throttle body?
  10. #150
    LS7 throttle body. Adjusted the etc scalar for the new throttle. I been at this for 2 days already lol. It wont idle at all if i zero out the integral airflow tables. Even after reving and holding it past 1500 for a few seconds.
  11. #151
    Jan 2014
    Australia
    1,982
    are u SD only or maf also..? if ur SD then check the "effective area" "min fail" mine was too high on 5.0 u can try that at a lower value see if it helps
  12. #152
    Jan 2009
    Spokane, WA
    480
    Vacuum leak?
    Why do people automatically default that it's the 'tunes fault'? ie Your tune is making my old, freshly flowed/cleaned injectors stick wide open. no.....Your shit is fucked. Not my fault that even when they are unplugged from the harness, they continue to spray. And not my fault you hydrolocked your motor and bent rods, too.
  13. #153
    MAF only but i figured it out yesterday. I tried bringing down the overspeed spark correction and underspeed spark correction from -17 to -15.3 and it idled down to target idle. Now it runs good just having idle going too low when coasting down at atound 30-35 mph. It goes to 500 and up to 800 and so on for a few seconds. Gonna try adding spark to coastdown table.
  14. #154
    Interesting thread and concepts. Thanks for taking the time to share. Even though my HCIE 2007 Z06 idles quite well this made me revisit all my idle tuning from scratch since I did it all before I changed intakes, CAI, TB, and changed to E85. I used to be able to get my car to idle at 850 rpm with adaptive idle turned off, but now it's not steady at all. Luckily it's pretty darn good with adaptive idle on though. Tonight I tried idle timing from 15 to 22 degrees with adaptive off and couldn't get it to idle steady with my current abase airflow numbers. The timing changes didn't seem to make any difference. I'm guessing the NW102 might be to blame, but who knows. At least it's pretty darn steady with adaptive on though. I was just trying to fix surging I get during SOME hot starts. Haven't made any progress yet and I'm having trouble recreating the issue. Sometimes on hot starts the idle won't be steady for a good 30 seconds or so if I had to guess. I don't know why it only does it sometimes though. I thought I might need to play around with the open loop fueling, but I found that it goes into closed loop after 10 seconds anyways, so unless I changed the time it takes to go into closed loop, I'm not sure what else to mess with.
  15. #155
    Really good write up! Thanks a lot. There wouldn't happen to be one like this but explaining MAF Calibration for the e38 ECM would there?
  16. #156
    13,565
    The MAF calibration is still the same for almost any of the GM V8's back to like 98/99, tuning them is the same process.
    There is a write in the VCM scanner section about using fuel trims and a wideband to tune the MAF or VVE which a E38 uses.
  17. #157
    Trying this method out but I cant figure out why my spark is still not locked in at 24 degrees. Any idea on what I might be missing?
  18. #158
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    I don't know how it is idling with 1.89g in all of the Base Running airflow table? Your idle spark says 16, not 24. Anyway, here is my BRA table for reference. It is probably not correct for your car, but closer than 1.89. Where is a log?
    If you look at your idle spark table, and it is idling at 60kpa at 1000 rpm, then it is in the 6 degree range.
    2013 Silverado 5.3, 6L80k 8.8
  19. #159
    Yeah, I didn't realize I had it in lb/hr instead of g/s. I figured that part out haha. Anyways, I was able to get my spark to lock in without touching the idle spark and just using the HO/LO table method discussed. Regardless, I still cant get this thing to idle trying this method. My truck will idle just fine with my original tune from the previous tuner but I just like tinkering with things to try and see if I can make it any better and of course to learn. I have to always have my foot on the gas in order for it to stay running. As soon as I let off, the rpms instantly drop to low and it dies. How can I get it to command more TPS without giving it some throttle? I started with 5g/s, 9g/s, 12g/s and then 15g/s and didn't notice any improvement. I still had to keep my foot on the gas. This is a 5.3 with ported heads, 224/228@114 cam with around .580 lift, 105lb injectors, e85, lS3 throttle body, turbo, factory intake, 1:1 fuel system.
  20. #160
    Jan 2014
    Australia
    1,982
    your base running airflow v ECT mult is zeroed out try that back to stock, and ALL your "follower torque" is zero too that wont help at all go back to stock, and all your adaptive airflow corrections are zeroed out that means that the ect isnt going to help at all, to dial in idle airflow put all those airflow tables back to stock and then zero out the spark correction tables and set idle spark tables to all the same say 16 then main spark to all 16 also so idle spark stays steady, then see what its like and adjust the airflow tables to dial it in and then once its good use spark as the last help (spark correction should be minimal if airflow is setup correct) also with those spark correction numbers maby try halving them
