Originally Posted by
lencomatt
Stock converter, the car had been tuned previously with the stick, it ran fine. I loaded the fuel and maf info from the stick tune and it does this. Its the same maf curve that was in the stick tune. I have the curve from Pro M, it starts with 673.4hz=0lbs/min and goes to 12004.8hz=128.61lbs/min, top to bottom. The chart in the car is inverted so it start with 12004 at the top and 673 at the bottom, will that make any difference? All the points in the chart have been converted to microseconds. What other info do you need?
