Originally Posted by
dr.mike
For the X-series AEM widebands ( 30-0300 and 30-0310 ), the analog output is, generally, preferable to the serial output.
The new AEM widebands have a differential analog output; that is used to compensate for ground offset errors. This makes a huge difference in accuracy.
The Analog- wire of the wideband is not really a ground wire. It is an input wire that the wideband uses to determine what the logger THINKS proper ground voltage actually is. Then it uses that voltage to set the voltage on the Analog+ wire to match the correct differential.
e.g.
The wideband wants to signal a value of 2.5v to the logger ( for whatever lambda value that is )
If the wideband measures 0.3v on the Analog- pin. It adds that value to the 2.5v it normally would have used. And, it outputs 2.8v ( 2.5v + 0.3v ).
But, to the logger, that 2.8v appears as the original proper 2.5v value.
Thusly, the signal is "auto-corrected" for ground offsets between the wideband and logger. ( within the limits of the power rails )
To use this with the MPVI PRO:
Connect the wideband brown wire ( Analog - ) to the GND pin of the MPVI ( pin 5 or 6 ).
Connect the wideband white wire ( Analog + ) to the A/D INPUT x pin of the MPVI ( pin 1 .. 4 ).
This will cause the wideband to use the MPVI ground as its reference voltage. Thus, compensating for errors caused by differences in ground voltage between the MPVI and the wideband.
The analog output of the 30-0300/30-0333/30-0310 runs at 500Hz (2ms) with 10-bit resolution.
The serial output runs at 10hz (100ms) and is only 3-digit data xx.x AFR.
I don't consider the serial data to be super useful.
