Excellent work guys!
I'm also interested in this Min/Max Override feature, so I can do away with injector scaling. How do you use it, and how do I know if the memory of my P12 controller will support it?
Now if only the differences view worked.
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
The test is simple. Try to change a parameter outside of the bounds of the min/max limits listed below in the parameter details section. If the parameters limits are not the true limits of its particular data type, you will receive a pop up message alerting you that you are exceeding the limits.
We got this guy Not Sure, ...
Support just emailed me asking if it was fixed in 3.2.9. I confirmed it is not.
Would it be possible to use hpt for 68rfe tuning while retaining 6.7 cummins support with competitor tuning?
Can you please elaborate on the slave OS part? How do we access it?
Will you support reading the slave OS? Thank you.
Good news.
Thank you HP Tuners team
Is the VVE row axis bug fixed?
Excellent! Thank you guys for the hard work!
I seem to be experiencing an installation problem.....anyone else having this issue, and perhaps a way to correct it?
'17 Whipple'd S550
Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
Any support for the slingshot polaris
Open an E38 or E67 tune. Go into the Edit menu and hit "Add Slave Segment Data."
This was added to allow customers with aftermarket throttle bodies to adjust P1516 DTC thresholds that can cause the vehicle to go into reduced engine power mode. The feature has the nice side effect of being able to truly write entire an ECM (initialize another ECM with the exact same tune).
The slave segment section cannot be read back with the standard read process, but you can always add it this way.
Regarding the P1516 thresholds--any way to do that on E40's or only E38/E67 in V3.2?
