Page 23 of 23 FirstFirst ... 131920212223
Results 441 to 459 of 459
Thread: VCM Suite 3.2 is here!
  1. #441
    May 2013
    17
    Send support copy of tune and screenshot. Had some issues with it on mine too and they fixed it pretty quickly
    found the problem. you now use a comma , instead of a point .
  2. #442
    Apr 2007
    1,104
    Quote Originally Posted by Sennin View Post
    that needs to be fixed as the industry standard is a period for gear sizes and tire dimensions in inches.
    The most hated, make the most power.
    93 Ranger. 5.3 D1X. 1069hp.
  3. #443
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yeah, that's weird
  4. #444
    Oct 2013
    228
    Yes
  5. #445
    Has anyone here had the amount of User defined math parameters change in the scanner before? Yesterday I was showing the regular amount of 20. Today I am only seeing 10. Same software on my desktop shows the 20.
    I have tired uninstalling and reinstalling the software. But it still remains the same. I even tried an older version of software.
  6. #446
    Sep 2002
    Chicago, IL
    6,397
    The list is dynamic, and will show more slots as you use them.
    We got this guy Not Sure, ...
  7. #447
    Thanks for the reply Keith. The strange thing is that I was using 10, 14 & 15 last night.
    When I fired up the scanner to do some logging this morning a few of the histograms/graphs didn't populate because the math parameters weren't in the list anymore that I used last night.
    I took the VCM Scanner.cfg file from my desktop computer and put it onto my laptop and all seems good again.
    I'm just puzzled as to why they disappeared.
    So what you are saying is that if I use up all 20 user defined math parameters currently listed on my computer the software will make more slots available?
  8. #448
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yeah, surprised me too a while back.. adds them as needed.
  9. #449
    Apr 2007
    1,104
    i know that the maf hz scaling would auto populate on the 2.24 scanner setup. What happened to this feature in 3.2? {as far as the hz range, 0-12500 ranges. each ecm has a different range it works in and 2.24 would populate this accordingly.}
  10. #450
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    It's one copy/paste operation, very easy.
    It only worked for a small number of ECM's in 2.24 so it was not carried over to V3 and newer.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  11. #451
    Apr 2007
    1,104
    i know, it was convenient though when going from an lsj to an ls1 it would swap it.
  12. #452
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by Engineer@HPT View Post
    Open an E38 or E67 tune. Go into the Edit menu and hit "Add Slave Segment Data."
    This was added to allow customers with aftermarket throttle bodies to adjust P1516 DTC thresholds that can cause the vehicle to go into reduced engine power mode. The feature has the nice side effect of being able to truly write entire an ECM (initialize another ECM with the exact same tune).
    The slave segment section cannot be read back with the standard read process, but you can always add it this way.
    I have an 09 Z06, E38. I have the latest current pub of 3.2x and this option is not available in the Edit Menu. Has it moved?
    Thanks.
    Steve Williams
    TunedbyFrost.com
  13. #453
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Weird, doesn't show up for the stock 2009 Z06 file I have either
    Wonder if you just need to send it in for them to add that OS?
  14. #454
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Frost View Post
    Thanks.
    Yes, they've only added the data for some OS. You have to make a support request if yours isn't available.
  15. #455
    Jan 2006
    Richmond VA
    1,950
    Thanks.
    This issue is resolved as of the latest public and beta release, for anyone following.
    Steve Williams
    TunedbyFrost.com
  16. #456
    2004 GTO.hpt
    Can anyone tell me if this file (OS 12587604) has full Flex Fuel capabilities with this upgrade? I need a good "working" DBC Flex File for the P59 PCM.
  17. #457
    utah
    8
    I got into the vcm editor 3.2 and realized we no longer have access to turning dtc off and on. Am i missing something? Did it get moved?
  18. #458
    13,582
    Download 3.4 and try again.
    It just came out.
    Also you must be in advanced view under the edit tab to see everything. You can still disable DTC's, nothing was removed.
  19. #459
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Edit, view, advanced.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
