Page 5 of 23 FirstFirst 12345678915 ... LastLast
Results 81 to 100 of 459
Thread: VCM Suite 3.2 is here!
  1. #81
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by Engineer@HPT View Post
    I am fairly confident this particular adjustment will not cause harm to your ECM. It may do nothing or set a code at worst, but you should be able to flash back to the previous calibration without any issues.
    ok thank you
  2. #82
    We're a little behind on the supported vehicles list updates. We're hoping to get caught up today. The web guys just can't keep up with the engineers!!!
    Don't forget adding the 6.7 diesel in the repository.
  3. #83
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    redownload & reinstall.
    Got it, and works now. Thank You!
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
  4. #84
    Open an E38 or E67 tune. Go into the Edit menu and hit "Add Slave Segment Data."
    This was added to allow customers with aftermarket throttle bodies to adjust P1516 DTC thresholds that can cause the vehicle to go into reduced engine power mode. The feature has the nice side effect of being able to truly write entire an ECM (initialize another ECM with the exact same tune).
    The slave segment section cannot be read back with the standard read process, but you can always add it this way.
    Does this mean I could get second hand E38 and not need a Tech2 to write any HW compatible SW version into it? For example a 2010 E38 from a Camaro and replace the entire SW with 2010 Corvette SW?
  5. #85
    HPT Employee Engineer@HPT's Avatar
    Jan 2015
    fecadefa
    615
    Quote Originally Posted by barum View Post
    Aside from changing the VIN (which you can accomplish with an unlimited license), yes you can.
  6. #86
    Feb 2015
    33
    Still not able to read knock or injector duty cycles on dodge srt4 ???
  7. #87
    Apr 2016
    4
    So you answer about the ram 8spd????
  8. #88
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,772
    Quick question, each time I download a new release 3.0 to 3.1 to 3.2 I lose all my Math Parameters in the Tools>Math - Users list. They are in MATH folder under VCM Scanner, but the Math Parameters X all are vacant. Is there an easy way to repopulate this table?
    Ed M
    [email protected]
  9. #89
    Advanced Tuner 383_Stroker's Avatar
    Apr 2009
    258
    Quote Originally Posted by ElecTech View Post
    He said if it's a "hard coded limit," you'll get the message. Like early E38 injector limits, for example.
    Edit: Engineer treed me.
    Hey that's a good example. Does this mean we can put correct injector data on the older e38s? Or is that one that still has a hard limit?
  10. #90
    Tuning Addict
    Jan 2015
    6,832
    Quote Originally Posted by mowton View Post
    Ed M
    I haven't had this problem before... BUT also haven't updated in a week or so, NOW all of my custom math parameters are gone.......
    ~Greg Huggins~
  11. #91
    Sep 2002
    Chicago, IL
    6,397
    Are you guys using multiple versions of the software simultaneously? That complicates things.
    We got this guy Not Sure, ...
  12. #92
    Dec 2008
    on the Dyno
    1,825
    Quote Originally Posted by FastEddy View Post
    Yes, a bug... if you change the row axis in Tune A, for example to a 3 bar... then you open or pull a different/unrelated tune, the row axis on the VVE editor remains the same as the tune prior.
    I don't see this as an issue personally. The Axis in the VVE tool are phantom axis'. They aren't stored in the tune. It is only for visual of the EQ coefficients. You could put a 5bar tune in a NA car and it still wouldn't care because the zone boundaries you preset within the tune define the working range of the zones, not the axis within the VVE tool.
    Located in Central Kentucky
    ShorTuning
  13. #93
    Dec 2008
    on the Dyno
    1,825
    Quote Originally Posted by 96gt4.6 View Post
    So....am I the only one experiencing this installation problem?
    I've tried a full un-install, still no avail. Re start, still nothing. 3.0 installs with no issue. What am I doing wrong?
    Normally when I get that error it's because the software didn't download fully/correctly.
    ShorTuning
  14. #94
    Dec 2008
    on the Dyno
    1,825
    My Maths were also gone after installing the new 3.2.9 this morning.
    I am also having some trouble with finding some PID's within the scanner now. Particularly the CAN bus channel for the new CAN enabled AEM wideband unit.
    ShorTuning
  15. #95
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by LSxpwrdZ View Post
    Are you running any other versions of VCM Scanner on your PC?
  16. #96
    Mar 2007
    Florida
    3,772
    I was only running Version 3.0.128 and Beta 3.1.390....
    Ed M
    [email protected]
  17. #97
    Tuning Addict
    Jan 2015
    6,832
    No, didn't think ahead enough to save 3 or 3.1 before updating - honestly didn't see the need... Thought after the 3.0 release problems that this one wouldn't have the "immediate" issues
    SO all versions but todays 3.2.9 are gone....
    BUT good news is, from this day forward I WILL be saving all math parameters, histogram layouts and so on to excel or word files on top of what's all ready available
    ~Greg Huggins~
  18. #98
    Sep 2002
    Chicago, IL
    6,397
    Could be an issue with the 2.24 backwards compatibility with math parameters. Guess we'll have to remove that moving forward.
  19. #99
    Apr 2006
    573
    Hmm, with the change in the write entire feature... does that mean one could write on an empty ECM?
  20. #100
    Sep 2007
    393
    Still the same bug from when 3.0 was initially released...
    Nobody ever bothered addressing it back then so I figured I'll try again.
    Same scan from my 2015 Z06 (that was made back in April) opened twice for comparison/illustration purposes. As you can seem from the screenshot even though the spark values from the graph both read 15.5 degrees at two different points in time, the value displayed on the chart is VERY different.
    Any reason why?
