Customer brought in a 2010 Dodge Challenger SRT8 6.1L V8 Automatic for tuning, I am looking for help on figuring out what be my issue.
The car currently has not been tuned. Placed the car on the dyno, to being testing/tuning. And did a tune power run to get baseline numbers before beginning. The car's check engine light starts flashing, so I let out and investigate the issue. The code is a P0305 Cylinder 5 Misfire, the customer then tells me that he has been getting that code for a while now. He has install a new coil pack on cylinder #5. I confirm, that he did place it on the correct cylinder. So I start by swapping the coil from another cylinder to #5 to see if it moves or stays at #5. Start another run, light flashes, I let out and investigate. Still P0305 Cylinder 5 Misfire. So I then, swap the injectors to another cylinder to see if it moves or stays at #5. Start another run, light flashes, I let out and investigate. Still P0305 Cylinder 5 Misfire. So I then pull the spark plugs out to look them over. They all are brand new, I confirm with the customer. He states he just installed them when he installed the new coil pack. The gap on the spark plugs look great. So I swap both plugs from #5 to another cylinder, just for the heck of it. Start another run, light flashes, I let out and investigate. Still P0305 Cylinder 5 Misfire. So I tell him that I want to do a compression test on the entire engine. So I start a compression test on all cylinders.
Here are my results,
#1- 205psi
#2- 210psi
#3- 207psi
#4- 210psi
#5- 250psi
#6- 205psi
#7- 210psi
#8- 207psi
That was not a typo, #5= 250psi.
The test was done with all injectors and all coils connectors disconnected.
I have not done a leak down test yet on the engine, just was very shocked to see how much higher cylinder #5 is over all of the other cylinders.
The vehicle has 80,061 miles on it.
What are your thoughts? The car idles very smooth, it will only register a misfire when driven aggressive(stated by the customer). I have not drove the car on the road to confirm.
