I go to do a fast learn on my 6l80 trans. It says the temps are too low. So I install the trans fluid temp PID and it says 32* F and never changes. Trans Gauge says 180. What could cause this?
Figured it out
Where your cells are on the left side right click on an empty cell and insert the PID manually. When I did mine there were two or three different trans fluid temp PIDS. I chose all three and then kept one that worked.
