Page 2 of 12 FirstFirst 123456 ... LastLast
Results 21 to 40 of 239
Thread: done dug a hole i think
  1. #21
    Tuning Addict
    Jan 2015
    6,803
    If you can get a list of what has been replaced... It will help a lot for everyone... Then I would get some ID1000's to be real safe all though you can honestly get away with ID850's if the owner is worried about cost... The Injector Dynamic injectors will be best for you just simply because they'll have all easily accessible and useable data to plug straight into the tune and also they won't cause you other headaches during tuning...
    ~Greg Huggins~
  2. #22
    Jun 2013
    207
    ok stock 6,0 trailblazer tuned by tuning school for a demo , so no clue what all they changed, ran great , now has that supercharger duetchwork 42lb injectors ? dbw tb ls2 I think maf
    no clue map no clue
    but can get whats needed
  3. #23
    Jun 2013
    207
    how do I fix the map maxing out?
  4. #24
    Tuning Addict
    Jan 2015
    6,803
    Quote Originally Posted by jessiewalls View Post
    Install a 2 bar or 3 bar map - you can install a 2 bar ss cobalt map for what boost your running then just input the parameters for the new map into the tune - I'm almost 99% sure the cobalt map is a direct plugin for that year model, but not sure sure....
    OK after the injectors are corrected and a correct map installed we can go over fixing the rest
    ~Greg Huggins~
  5. #25
    Jun 2013
    207
    I'll git right on it which map peramiters do I change?
  6. #26
    Jun 2013
    207
    Is there a gm injector that I could use , I git a better deal on gm parts
  7. #27
    Tuning Addict
    Jan 2015
    6,803
    Airflow - General - MAP
    You'll also want to send in a request to HP Tuners via their website to get manifold volume added to the tune - they can hopefully get this done while your waiting on injectors to show...
    ~Greg Huggins~
  8. #28
    Tuning Addict
    Jan 2015
    6,803
    Pretty sure your already passed the 60lb mark for your engine displacement and boost... ID might be able to give you some sort of deal if your a dealer or willing to become one?
    ~Greg Huggins~
  9. #29
    Jun 2013
    207
    Injector dynamic 1000cc is that all I need to ask for , I'll prolly try to go threw. Atec or speedway they can usually git shit quick
  10. #30
    Tuning Addict
    Jan 2015
    6,803
    Looks like Atech has them -- all though they list them a little differently....
    ~Greg Huggins~
  11. #31
    Jun 2013
    207
    And I did wire in a magnavolt fuel sum thing or another to increase voltage to fuel pump during boost
  12. #32
    Jun 2013
    207
    Hell yeah now that's idiot proof
  13. #33
    Jun 2013
    207
    I assume I can snag the cobalt map parameter outa the repository will the year matter or do those values remain constant
  14. #34
    Tuning Addict
    Jan 2015
    6,803
    Does your map bolt to the supercharger? I think the cobalt one snapped on??? You may need to use the ZL1 map and change over the connector to work. I can post those part numbers tomorrow if I can remember where I stored them Removed the photo for the atech reference - wasn't sure if I was allowed to post pricing like that?
    ~Greg Huggins~
  15. #35
    Jun 2013
    207
    It pushes in a hole in the back of intake with a half strap bracket holding it down so mounting ain't an issue and I got connectors out the wazu
  16. #36
    Jun 2013
    207
    I already got the injector info wrote down thanks, I gotta bunch a different part numbers for map sensors most common seems to be cobalt sensor ,
  17. #37
    Jun 2013
    207
    2 bar should work , prolly ain't goin over 15 psi
  18. #38
    Tuning Addict
    Jan 2015
    6,803
    Sounds like you need the cobalt one then... Another thing while looking at the posted log - does this feel like it's missing? Looks like bank 1 goes from rich to lean rapidly - Make sure the miss isn't throwing off the air fuel reading - Pretty sure you need injectors, just thought you might want to check that one first...
    ~Greg Huggins~
  19. #39
    Jun 2013
    207
    alright i got a 12615136 map sensor what should the linear and offset be ? and is there any other changes that need to be made?
  20. #40
    Jul 2013
    Clear Lake tx
    423
    so I have to ask...if its a 6.0L with 8-10 lbs of boost why couldn't he run factory LSA injectors? that shouldn't max out the IDC on those. so I see that 57.8 PSI on the fuel pressure, is that regulated or bumped up at all? I didn't see it move. but with the factory LSA putting out 9 lbs of boost at 65 psi rail pressure it seems like those would be sufficient.
    2010 CTS-V A6, Airaid CAI, 2.4 pulley, ported ls7 throttle body, ID850s, ARH 1-7/8" headers and X pipe, TR7IX plugs, MSD wires, Elite catch can, ZL1 lid and Track Attack HX
