Can you have different TM for normal and performance mode? I'd like to keep a fair amount of TM in normal mode and a lot less in performance mode.
There really isn't a performance mode on a 6L80e. My truck only has pattern x and pattern y but everything is on pattern x.
Removing alot of TM isn't suggested on a 6L80e. Just set up or shift speeds and pressure and it should perform just fine around town and still shift quick and chrisp under WOT situations.
