For the life of me, I can't understand why you'd ever want to use a negative driver demand value - especially at pedal positions greater than 0. From what I've read on this forum, negative driver demand values actually cause engine braking. I guess I can somewhat understand wanting engine braking for the 0 pedal position, but why would you ever want engine braking when you are pressing the gas pedal??
For example, on my car (2012 Impala - 3.6l direct-injected LFX V6), the stock tune has negative driver demand values for pedal positions as high as 4% when going as slow as 31mph. If I press the gas pedal - even as little as 4%, I would expect the engne to produce more power than it currently is, not less - and certainly not "negative power"! :-)
The 2106 Z06 Corvette stock tune has negative values up 12% throttle!
From what I've seen, this is the "norm" for direct-injected vehciles (not 100% sure about that, just what I've seen in the tunes I've looked at).
What am I missing here?
Thank you!
