Lift and larger tires question
I have a 2014 5.3 Silverado with the A6 transmission. I just put a BDS lift on the truck and 34.5" tall tires. I have done some searching but haven't found a guide/sticky or how to, for tuning for larger tires. Do I just update the VSS Pulses per rev,VSS Pulses per rev - trans, VSS tire revs per, and VSS tire revs per - trans?
Thanks,
Rob
in editor / edit gear and tire wizzard
I found out how easy that is with the new software, but I didn't know if there was any further trans editing that would need to be done. I have already drove it since the edit and it feels much more like stock.
I haven't played with anything that new but gm is the most popular so I don't see why you couldn't modify Trans pressures etc. But tire wizard should set you up for the bigger tires.
