Finally got my exhaust bung in and the wiring done. I hooked up the LC-1 per soundengineers diagrams. Am I correct in saying that all grounds go to pin 5 on the EIO and the Blue wire (heater ground) from the LC-1 gets grounded to the frame? I ran the blue wire back through the firewall and grounded it to a screw near the battery that is used for other grounding. Is that right?
When I look at the sensor in log works I see 14.6-14.7, but in hpt using the LC-1 it cycles back and forth between 10 and 14.0. Oscillates like a nb. I have the brown wire, analog 2 coming into the #1 on the EIO. Is it a ground problem? Where can you ground it so you don't get a ground offset? To the DTC connector?
When I programmed the LC-1 through log works I set it to 1/6th on the analog 2. I had the serial connector going into the serial out connector and the serial in was plugged with the terminator. Is that correct? Do you leave it that way? When would you switch it the other way?
In logworks under analog 2 I set it to AFR instead of lambda and then set the top voltage to 1.0 and the bottom to 2.0. Then I set the AFR on top to 10 and the bottom to 18. Is that correct?
In the table view, I inserted the wideband lc-1 under the eio input 1. HELP
