I have a Dynojet Wideband 2 that I have used in the past that worked fine. I recently upgraded to the newer version of scanner and for some reason I can't seem to get it to respond. I have tried everything I know to do and I just get a reading of 10.00 AFR no matter what. The sensor is heating up like it is supposed to and when I run the test with the wideband 2 module it is showing that my sensor is in good shape. Any help would be greatly appreciated. Thank you! Luke
