EcoLPI Injector Values
I own a Ford Falcon FG MK2 EcoLPI. I am having difficultly tuning the car on the fuel side of things as nothing seems to work to affect the AFR.
The thing that is puzzling me is that the Injector Numbers are identical to that of the NA Petrol Model of this car. EcoLPI is run on dedicated LPG and does not share the same injectors as that of the NA Petrol model, so I don't understand why these values are identical.
you sure the injector data is the same? all the injector settings are different when i checked.
what tune are you using to compare against it?
