Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Idle timing
    Feb 2014
    Sydney
    295
    Idle timing
    Can anyone shed some light why idle timing has a setting of 60 degreees? While an LPG car has realistic figures for idle timing.
    Tune with actual data not simulated data!.....Applied Road/track Tuning
    Aug 2015
    25
    It may be a maximum allowed limit rather than a desired value.
    I base this assumption off the values in the "Low Load Maximum" table which has the same spark values and is described as, "This table provides a maximum spark limit when under low load conditions in relation to the time that the engine has been operating at low load".
    As with all assumptions I could be completely wrong.
    Jul 2009
    326
    The two idle tables aren't used at idle but do form part of the calculation. The ford spark strategy, in most cases, will use the lowest timing value out of a given calculation.
    Feb 2014
    Sydney
    295
    Quote Originally Posted by IH8TOADS View Post
    Thank's for the responses. Given what you have said I will see if I can get control of the idle timing today.
    Puffwagon, great foot note!
    Aug 2015
    230
    I had a look at the PCM code and they do not appear to be referenced at all. All the tables in this screenshot are referenced in the spark routine except for the "Spark low load maximum", "Spark Idle In Gear ECT" and "Spark Idle In Park/Neutral". I believe this is why they are all set to 63 from the factory.
    I may be wrong and they are accessed indirectly somehow but I can't seem to see where.
    It appears we are missing another table for cold start idle timing, you can modify cold start when you aren't at idle but there is another routine that controls the idle timing when cold. I tried to find it but no such luck yet.
    Jul 2009
    326
    Rolls, I use the idle tables on every single tune I do. I can assure you they are referenced.
    Aug 2015
    230
    Interesting. So changing them from a value of 63 to something lower will actually limit the idle timing? Are you able to send me a .hpt file where you find they are used? Curious if it is only some strategies that use them, if not then I'd like to figure out how they are referenced as nothing addresses those locations where as all the other tables are referenced directly.
    edit: seems they are accessed differently to the other tables.
    Feb 2014
    Sydney
    295
    It responded exactly as you said it would, thank's
    Jul 2009
    326
    On my cammed Barra with 0.65 spark gap and e85 I run a measly 6 degree of advance at idle. I don't usually run more than 10 to 12 degrees on a Barra. My Evo's i'm down around 5 degrees.
    Aug 2015
    230
    Other than it adjusting the actual rpm what are the advantages to running more/less timing at idle?
    Do you know how to increase the idle timing at cold start? Mine runs -2 to 0 degrees for the first few minutes which is super loud. I've managed to stop it running warmup timing at cruise but not at idle. I could try disabling cold start entirely but not sure I want to do that.
    Jul 2009
    326
    Idle stability and prevents misfires. It won't affect RPM.
    I would have to check what HP can access and if so what's it's called in HP language.
    Aug 2015
    230
    Less timing prevents misfires or more?
    Why does it prevent misfires?
    Jul 2009
    326
    Less advance will prevent misfires/popping. The rpm is low therefore you don't need to run 20ish degrees advance (like 99% of people tuning Barra's) and I don't care for emissions.
    Aug 2015
    230
    Cheers for the info.
    Aug 2015
    230
    IH8TOADS I tried editing those tables on my car and confirmed it changes nothing. I set them from 63 deg to 0 deg just to check and nothing changes at idle or neutral when cruising.
    Perhaps they are only used on the auto cars?
    Spark Min idle only appears to be used in open loop idle, eg if you put the car in neutral when you are going more than 5kph it will use this ignition number, once stopped it ignores the number and uses closed loop idle ignition timing.
    Jul 2009
    326
    It will work, you're doing something wrong or your software is f u c k e d.
    I have used it on BA to FG manuals, it works.Setting to zero is not a good test for spark in this case, set to 10.
    Aug 2012
    Melbourne Australia
    344
    Quote Originally Posted by rolls View Post
    Rolls, lets take this offline but like a whole heap of scalars and tables "Spark low load maximum" is referenced indirectly There is approximately 320 of these indirectly referenced tables as well as things like the TMAP and Boost Slope and Offsets
    Feb 2010
    Perth Australia
    480
    Darryl why take it off line? It's all useful info.
    Roll's can confirm the idle spark tables directory influence idle timing. Is your spark source idle control when idling? Perhaps you have an issue with the car preventing it from use idle control as spark source?
    Aug 2012
    Melbourne Australia
    344
    Luke, because I am not sure HP Tuners will want me discussing on an open forum how to track these down. Especially the scripting of it and how once you have done one then you can automate the entire process for the remaining calibrations
    I will ask if you wish.
    Feb 2010
    Perth Australia
    480
    Maybe they would like that? Might speed up the process? They are hiring by the way.
    04 Velocity MKII M6 & 06 BF F6 555 ZF6
