need stock tune for 5.7 2008 magnum
I needing a stock tune for a 08 5.7 magnum can someone please send me one
guy brought the car to me and someone has tried copy paste a 6.1 charger tune in it and im guessing it has wrong trans configuration in it bc when you put in into gear it takes like 5 seconds to recognize that its in gear
Seems like you have the incorrect gear ratio programmed in there.
when you are in the scanner, connected to the vehicle, hit the green looking button (special features) and run through the setting the gear ratio procedure. What does it show as the current programmed gear ratio? I believe the 5.7 in 2008 had a 2.84 while the 6.1 had 3.06.
I did I programmed it with the 3.06 which is what was put in the car and it is still acting like that, the car had a tune in it when It came to me and it wasn't running right so I was just looking for a stock tune to so I could just start a tune from scratch, it has 80# injectors and a 400 pump and a procharger on 8# and a 6.1 top end and a 3.06 rear
