Results 1 to 3 of 3
Thread: Fuel trims after new cam
    Dec 2019
    I'm wondering if I should be looking for an exhaust leak. Attached is the scanner data. I have adjusted the VE tables based on the averages and got everything to zero. However, I'm noticing that my banks are far opposites of each other. Is this normal? I'm thinking I might have a leak or bad O2 sensor. You?
    Thank you for any help.
    13,565
    If you flip flop o2 sensors side to side and the it moves the issue, then a bad o2 sensor could be likely but you may still have a lot of tuning if both turn way positive or negative.
    The VVE or VE and the MAF both need to be corrected.
    More thing can be looked once we know if the o2 sensors are okay.
    Dec 2019
    Sometimes you look at a problem for too long and don't see clearly. I should have thought of that, thank you. I'll swap them and scan again.
