Honestly at this Point I've had the tune changed so many times and it seems to make no difference I'm starting to wonder if it is something mechanical it's totally intermittent I can drive it for 10 minutes and not have it do it at all then I'll put it in reverse give it a little time and it will idle up and down up and down pulsing me backwards wanting to die unless I hit the brake or give it gas so far I've changed the plugs checked the brand new MSD wires and tried my best to take some carb cleaner and spray it around the supercharger and vacuum lines with no change in idle and all my grounds and electrical seem to be fine
