Results 1 to 13 of 13
Thread: Problems matching axis labels in tune file to compare file
    May 2007
    314
    I am missing the boat on this....
    I am (for example) trying to copy resistance values from a compare file to those of my tune file in the editor, but the axis labels are not identical. I can copy and paste values, but not the actual temperature (labels) from the compare file to the tune file??
    the compare file, for example , might read (in degrees on the axis labels)
    224 200 185 wheras in my tune file, they read
    192 188 175
    I can copy axis labels, but paste is greyed out ?? (both tune and compare files are from same year, model of vehicle)
    Any thoughts? (v3.2)
    thanks
    2003 MY Z06 3.3 liter whipple ...sold at around 1000 rwhp
    wip 2015 Silverado w/2.9 Whipple (phase 1 completed) phase 2 in the works
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Post both tunes
    Worst case, open the second file separately and copy the table labels from it that way
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    May 2007
    314
    Post both tunes
    Will look at this more a bit later...thanks for the response
    May 2007
    314
    Post both tunes
    Couldn't get that to work either?
    here are some files
    try... Engine--Airflow---IAT sensor cal.........can't copy with axis from compare to tune file
    thanks
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    You're going about it the wrong way. The copy w/labels doesn't work like that.
    Open up the IAT calibration table on the tune that has the data you want to use. At the top, where it says "Resistance", click on that. That will open up a table of just header values.
    Select everything, right click, copy (not with headers)
    Go to new tune, click on resistance to open header values.. paste the new ones in
    Then copy/paste the IAT temp values over to the main IAT table
    Save/close/re-open the tune. Should be good to go now.
    You usually at least have to close the "engine" window before the new headers will show up but closing/reopening the tune altogether will ensure it shows up
    (As a side note--any axis header that is underlined can be clicked on/opened/edited)
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    May 2007
    314
    tried 3 times, no go....I am missing something
    compare file 1st column is 67 , tune file is 57
    never changes??? v 3.2.38
    also, I have no option for copy with headers anyhow??
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    I just told you how to change the axis labels. And like I said.. save/close/re-open the tune after changing the axis headers so they'll show up. They won't change at first.
    I've done it on your tunes no problem, both directions (wasn't sure which was which), but it 100% works.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    May 2007
    314
    will keep trying, thanks
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    You can't use the compare feature to do this also.. have to open both tunes separately. Common mistake
    May 2007
    314
    ok, now it makes sense
    thanks so much...saved my life....again!!
    May 2007
    314
    as a possible convenience , perhaps hpt could implement a change to allow users to do this without having to open up 2 iterations of the software?
    Kind of clumsy on a laptop screen....lol
    In any case, it's all done
    thanks again!!
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    No problem
    Yeah, you used to be able to.. not sure why that feature didn't make it into V3
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    I'm having a difficult time with this myself. On the tune I'd like to use, RPM on the X axis is underlined and can therefore be copied. On the tune I need to copy it to, it isn't underlined and nothing I do will allow me to make any changes.
