Results 1 to 16 of 16
Thread: Couple more hellcat questions
    Sep 2011
    Portland, OR
    518
    We turned the NN off and calibrated the VE using the loaded dyno.
    Then moved on to WOT testing.
    Power is 800+
    I notice that the fuel system status indicates CL. Any other Dodge will show OL with your foot on the floor.
    Is it really in CL at WOT? Due to the wideband O2 setup?
    I changed from logging Desired FA Cyl 1 to AVG FA Open Loop and now it follows the FA table.
    By the FA it appears to be commanding 11.49:1. FA = .0872
    However, EQ commanded is .828 Lambda. Or approx. 12:1. Our tailpipe sniffer says it's at 12:1.......but it usually reads about .5 points higher than a WB screwed in the exh.
    I'll do an experiment. I left the Stoich at .0722
    Lastly, what is the function of the MAF? On GM it takes over fueling at 4K rpm. Is it simply a measuring device on the hellcat?
    Ron
    Y2K C5 A4 Coupe (10.78 @ 127) Cathedral port 6.2
    S476 L33 5.3 69 Nova 8.76 @ 158 Drive to the track street race car
    06 Cobalt SS bought new
    Sep 2006
    Syracuse, New York
    299
    Are you sure it has a MAF? Haven't seen any Dodge/Chrysler vehicles with a MAF yet
    Sep 2011
    Portland, OR
    518
    Card style MAF located in the intake tube.
    Also has a MAF calibration table
    Hellcat is a different beast.
    I changed the FA tables. Made the pressure ratio version richer than the Aircharge version.
    It's using the aircharge FA table. And the EQ commanded dropped to match.
    I suspect the offset in values is due to the odd FA Stoich value.
    AF by the internal widebands is ruler flat. So if it is indeed trimming while at WOT, it does a damn good job of it.
    Dec 2014
    Palmetto, FL
    874
    Quote Originally Posted by HackAbuse View Post
    Dec 2014
    Palmetto, FL
    874
    Quote Originally Posted by RonSSnova View Post
    Ron
    I have not even noticed to watch the Fuel System status while testing.
    Dec 2014
    Palmetto, FL
    874
    Ron
    As far as I know of so far, the MAF is there for airflow measurement only, not providing a main purpose of fueling control like the GM's.
    The last one i did was closed loop the whole time...pretty good at doing it too.
    Tony
    Sep 2011
    Portland, OR
    518
    Ha! I just noticed it in the graph display. It still showed trims.
    I did an experiment. I leaned the injector pulse it uses at WOT by 5%.
    Fuel didn't change......neither did the trim at WOT
    Somewhat of a mystery there......
    Jul 2015
    925
    after warm up it's always in CL due to the widebands.
    Sep 2011
    Portland, OR
    518
    I finished the tune. Did quite a bit of driving working on the VE table. Not sure why it's thought you can do a few quick drives and its nailed......
    Anyway it came out fine.
    With the NN off, it really struggled at start up.
    I simply modified the FA cold start table to give it some fuel, I could tell it was too lean and its happy as a clam starting now.
    So we put slicks on and took it to the track.
    Had issues with the inter cooler pump not turning on. That basically pisses it off. The IAT table thankfully removes timing. In the form of short term KR btw.....
    Fixed that and it went 133. 10.6.....
    Somewhat disappointing actually. Our track sucks, it spun pretty bad even with bias ply slicks.
    We did not turn off any tq management. Not sure what the trans will handle......
    Any suggestions appreciated. I think it should go bottom tens, closer to 138 given the power it made.
    Ron
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    Is it a stick?
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Sep 2011
    Portland, OR
    518
    It's an auto.
    And actually, after running the numbers through the Wallace HP vs weight and mph program, it's right about where it should be.
    Heavy cars!
    Mar 2006
    Kuwait
    1,564
    great, did you increase the auto upshift? Auto shifting at 6500rpm would really help with the ETs.
    Bader Norris
    MEP Tuned
    Instagram
    Sep 2011
    Portland, OR
    518
    I had all the rpm set to 6400. But it was shifting at 5900. I'm not sure what mode he had the car in while racing.
    Mar 2006
    Kuwait
    1,564
    check your DM..
    Bader Norris
    MEP Tuned
    Instagram
    Sep 2011
    Portland, OR
    518
    Got it!
    Thanks!
