Results 1 to 13 of 13
Thread: Writeup for logging AFR though Serial port?
    Apr 2011
    7
    I have a headache from searching. Is there anything out there for the noobs?
    13,559
    http://www.hptuners.com/forum/showth...tarted-Threads
    These are some of the currect write ups, maybe it's there.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Not a whole lot to write up on this one..
    Right click in channels list, hit add channel. At the bottom of the list (under external inputs) you'll see "serial port". Find your WB and unit in the list.. double click it, and you're done.
    Connect WB to serial port and Scanner will automatically figure out what port it's on, no config needed
    Serial inputs are a bit hit or miss.. seems the AEM one works pretty well, Innovate is hit or miss last time I tried.
    If the channel disappears or is blank when you start logging then it isn't working, either from not being connected properly or from the WB manufacturer not following their own serial standards
    May 2016
    Adelaide, Australia
    246
    I am using a Zeitronix ZT2 that is not supported by HP Tuners for serial logging.
    I have an arduino setup to read the zeitronix, and can then convert it to output any string i would like.
    In this case i want to output it in the format HP tuners is expecting from the supported devices.
    Any chance you know what standard any of the supported devices use? I have searched and can't find any info, and from playing around so far have not had luck.
    Cheers
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Data protocol should be defined in their users manual...
    i.e Innovate ... http://www.innovatemotorsports.com/s...eriallog-2.pdf or AEM .... http://www.aemelectronics.com/files/...ns/30-0300.pdf
    Ed M
    [email protected]
    May 2016
    Adelaide, Australia
    246
    Quote Originally Posted by mowton View Post
    Ed M
    Thankyou for that. For some reason i thought i looked at the AEM manual but didnt see that info.
    Based on the fact the AEM unit only outputs the AFR, i figured i would go with that.
    from the manual >
    The format is simply the value followed by a
    carriage return and line feed, e.g. "14.7\r\n"
    which is how I have set the arduino to output, but for some reason still not clicking with the scanner.
    I am sleepy, so will need to have a look tomorrow. I am sure it is something silly.
    Mar 2007
    Florida
    3,773
    Perhaps the info in the 4110 manual is better. Sorry it didn't copy and paste the best :-) Google the maunal for a better look...
    Serial OutputThe serial output can be used for data logging when an EFI system is not accessible. To run thedata stream, a RS-232 (DB-9) Female Receptacle shall be purchased.123456789Figure 5. Wire View of RS-232 (DB-9) Male PlugTwo wires need to be connected to a RS-232 serial port. The BLUE wire from the AEM UEGOGauge shall be connected to Pin #2 (RX) on the serial port for receiving data. Pin # 5 (GND) onthe serial port shall be grounded. If a standard 9-pin serial cable is to be cut instead, the (RX)wire is typically RED and the (GND) wire is typically GREEN. However, this should be confirmedwith a continuity tester before attempting. (Figure 5)Use HyperTerminal for testing the data stream. This software is found on most PCs prior toWindows 7; other operating systems will require locating alternative terminal software such asTeraTerm or RealTerm. To find HyperTerminal go to: Start | All Programs | Accessories |Communications | HyperTerminal. Name the New Connection and click OK. Set the COM portto the one being used and click OK.Bits per Second = 9600Data Bits = 8Parity = NoneStop Bits = 1Flow Control = Hardware Page 9Verify the settings above and click OK. When power is supplied to the AEM UEGO Gauge, AFR(or Lambda) data will be displayed, as shown below. (Figure 6)
    Ed M
    [email protected]
    May 2016
    Adelaide, Australia
    246
    Hi Ed,
    What you initially linked was definitely helpful!
    The innovate obvioulsy has more functionality, as does the Zeitronix zt-2, making the serial stream more complicated as a result.
    Luckily the AEM is only outputting afr data , which makes it far easier to replicate.
    i think my issue yesterday was the fact i was using the arduino serial monitor to view the stream, and that was impacting the scanner from being able to connect.
    so, to update the thread, I did it! I have a MAX232 serial to ttl converter taking the data stream from the zeitronix to the arduino , then the arduino converting that to the format expected by the HP tuners scanner.
    Works great.
    the Zeitronix seems to have logged at up to 0.1 leaner than the serial data stream around stoich, and showing richer when leaner. I haven't driven the car, just a quick start and see what happened.
    As we know a voltage can be interfered with, however a data stream cant.
    if anyone is after the code i am happy to share it, even though it would be worth $1000 bucks due to my time wasted!
    Feb 2018
    7
    That's all good but how would I add a second serial wb sensor? After all, I've got 2 banks?
    Feb 2018
    5
    I have a lm2, my innovate software is logging this on the pc so the usb is connecting, but when I add the only innovate serial option in hptuners I get nothing. Do I understand that I'm just hosed then for getting it to scan in hptuners?
    Feb 2006
    11
    So if I connect the serial output of my AEM wideband to a serial/usb connector and plug it into my laptop, the HP Tuners software will look for it and find it if I select it in the channels list?
    I have been setting up my LM2 to communicate with HP scanner via serial, it works sometimes but not all the time so far, but only appears to log channel 1, is there a way to get it to log channel 2?
    Jun 2019
    I'm very interested in seeing the Arduino code.
    How does logger know which serial port to use?
