I zeroed best drivability and fuel economy and did a quick run around the block. It looks like it stays in MP0 almost all the time other than WOT. Once WOT it climbs through the MP points to OP and stays there. Enable%load is zero and enable throttle around 60 tapering down to 10 at higher rpm. Not quite the result I expected. Seems like you lose your VVT out of OP when doing it this way. Great for a CJ or some type of race car, which is probably why it's setup that way in their calibration.
