Hey guys having an issue with this Cammed, Procharged C7Z06 going into negative timing at idle Tune and log attached. Let me know what you think. -22 timing.hplC7Z-ProCharger-Cammed.hpt
What's your airflow at Idle?
Full Service GM Late Model Performance Facility
www.redline-motorsports.net
Follow US on FACEBOOK!
Follow us on Instagram! redline_motorsports
2 ways to get around it. Control your torque via airflow and DD or keep the minimum timing to a reasonable value at idle.
One takes time to precisely tune the motor and the other is a hack.
Bader Norris
MEP Tuned
Telephone: +965-55446651
Email: [email protected]
Would you be increasing or decreasing DD for a setup like this? Are there any good writeups I could read up on for these or is it all just trial and error?
Think about it this way to simplify things. The reason it's pulling timing at idle is because your idle is commanding a lot less torque then what your engine is seeing. You need to change the torque reading your engine is seeing by adjusting idle airflow. Decrease the idle airflow and the motor won't be trying to fight itself with timing to get commanded.
Half your airflow tables at idle and see where your timing ends up.
Bader Norris
MEP Tuned
is it good tune for c7 zo6 2015 lt4 cammed and pro charge F1A kit ?
