Results 1 to 6 of 6
Thread: Best place to ask questions?
    Advanced Tuner NJ_Phil's Avatar
    Jul 2016
    Flanders nj
    283
    Since there is ZERO "free" documentation, where/what is the best place to ask people questions on this board? Not necessarily to start a whole new thread going, but to ask simple questions like:
    Chart vs. Time:
    Can I display relative time between 2 points rather than subtracting absolute between an event ending and starting.
    Example would be to measure time between 20 and 60 mph.
    Sep 2002
    Chicago, IL
    6,395
    The board is pretty well categorized. For example, your scanner question, probably makes sense to ask in the VCM Scanner section.
    We got this guy Not Sure, ...
    Jul 2016
    Flanders nj
    283
    Searching existing posts is always best but info is usually buried within.
    Sounds a bit silly to start a thread to ask a simple question and get an answer, just didn't want to pollute the forum with crap.
    thx
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by NJ_Phil View Post
    Chart vs. Time:
    That's a Scanner question, so ask in Scanner section.
    If it were an issue with a specific tune/vehicle, then ask in the section for that vehicle
    And.. to answer your question, no.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Mar 2019
    Namibia
    4
    Question jeep jk engine and unlock pcm change
    Hi;
    please can someone help me i do have a 3.6 jk jeep 2012, engine is change to a supercharger 3.6 engine jk with a unlock pcm.do i need to install the 2015unlock pcm [how do i change the vin nr and the immobilizer ] or what is the best way, I do have both pcm and files on my pc ,read with hp tuner.
    help will be appreciated
    regards
    Frans
    28,260
    No you do not need to install a 2015 ecm into your 2012 jeep, simply read your jeep, edit, license, flash, datalog, edit, flash, repeat.
