I made a small change to the Driver demand tho mostly focused on cleaning up the torque/torque inverse. I also was starting to see some extensive short trim creep at WOT so I knocked that down 1% in the mass transfer. The thing I noticed subjectively is that I can feel in the throttle when the torque table has a dip in it - likewise I think that relates to if I cross over a big enough dip I get that hard torque cut. So I worked on making the torque table transition as smooth as possible between the IPC error adjustments from the last set of data logs I made. So here's the result for tomorrows drag test n tune. This is definitely an improvement from before. Idle is still occasionally hunting but that seems to be driver demand which I can work on this weekend.
added a follow up log for the new tune.
