I'm looking for some data on these injectors from the L77 motor. I swapped this motor into my 2002 Trans Am and am trying to get these injectors scaled properly but am unsure which data to use or even the size of these injectors. I've tried searching and can't seem to find a solid answer on what exactly these are. Through my own searching, it seems like they might be the LS3 injectors with a multiple hole orifice plate. If this is true would I be able to just use regular LS3 injector data? That is what I currently have it set up with right now using the conversion table I found on here. I would just like to make sure this is correct, the car seems to run and idle/drive fine with how I have it setup now.
Thank you in advance for any input!
