ATS 2.0T traction control disable?
I have been tuning my car some more and have just about all the Torque management turned off. If i turn off traction control and stabilitrac manually and i make a pull, if the car chirps the tires in 2nd gear the traction control activated light comes on the dash, it will then usually shut off by 4th gear. Can i disable this any way in the tune? It seems like when it comes on the boost datalog is irratic then will smooth out in the upper gears. btw this is an Auto AWD car.
I had one other issue when i foot braked the car built boost and launched it cut throttle hard so i lifted and drove normal but when i went to roll into it again it still had no throttle movement when it would start to build boost. I had to shut the car off and restart to get the throttle back under boost.
