Results 1 to 10 of 10
Thread: Trouble logging inj duty cycle
    Jul 2016
    Mooresville NC
    11
    I have a 2007 c6z06 with an e38. I am having trouble logging injector duty cycle percentage. I have the inj duty cycle parameter in my charts, but I can't find it anywhere to add in my channels list which is why I'm assuming I get nothing when I log. Is there a different channel I need to log to make the duty cycle percentage work on the charts? Also I'm using the latest version of the software. Thanks
    Sep 2002
    Chicago, IL
    6,395
    Sounds like you're plotting a Math Parameter.
    You need to add the channels that the Math Parameter uses to calculate it's value.
    To find out what Channels a Math Parameter requires, open up the Math Parameters Manager under the Tools menu. There you can find your math, and in the bottom right, it will show you the channels that you must add to your Channels list to support the Math.
    In the case if Injector Duty Cycle, you likely need to add Injector Pulse Width and Engine Speed (RPM) channels.
    We got this guy Not Sure, ...
    Jul 2016
    Mooresville NC
    11
    Quote Originally Posted by Keith@HPTuners View Post
    Awesome, I will try this. Thanks for the info, I figured there was a combo of channels I needed but didnt know how to figure out what was required.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Go to tools-->math parameters (or hit ctrl+m) to bring up the math parameter manager
    Find whatever math parameter you're wanting to use. Inj Duty cycle is under fuel flow
    Click on the parameter you want to look at more detail on.
    Over on the right side it will show you all the details about that parameter. At the bottom it will have a list of the parameters it needs in order to work. If a parameter is highlighted in red then you aren't logging it, and thus it can't be used. That means that math parameter won't work.
    SO--yeah, pretty much just log injector PW and RPM and injectors duty cycle will work.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Tuner seevi's Avatar
    Jan 2009
    southern California
    80
    Can anyone send me a screenshot on how to set up Injector Duty Cycle chart? I'm tracking the Injector Pulse width and RPM, and the chart is giving me some crazy information.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Post a log and your layout and I'll fix it.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Jan 2009
    southern California
    80
    When I try to post the files, HPTuners tries to open the scan file and my browser opens the layout file as an Xml file. Can I email them to you?
    Jan 2009
    southern California
    80
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Ya, PM me
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    Jan 2022
    901
    Were you able to fix his?
    And are ya still around?
    Thx
